wrong solution. thinking water in the gas
Took the fuel filter out and it was dirty as all hell. Replaced the filter lowered the car off the lift. Fired it up and ran awesome for about 2 minutes then started skipping again. I think the gas tank is so ****ty that its clogging the new fuel pump.im definitely gonna get the tank out without dropping the rear but still a royal pita. Would water in the gas make it buck and run like crap?
Re: wrong solution. thinking water in the gas
Lol not water rust. Fuel sock was plugged right up. Took 30 minutes too pull the old tank out. Broke a bolt off in the cross member though. Should be all good by 9:30 tonight
10-31-2016 11:09 AM
Deadbolt24
01-19-2015 01:29 PM
