X pipe set up...
X pipe set up...
I'v decided to go with the summit universal X pipe set up,
I was wondering how much clearence will i have after I put it all on?
i plan on having it connect to lt's, will i b able to lower my car a few inch's?
Re: X pipe set up...
With an X or H pipe, you are not going to have much ground clearance. No matter what you go with, you are going to be pretty low, due to the routing of the pipes themselves and the collector flanges. I never measured my ground clearance (stock ride height), but its not much. Its probably possible to lower it, but I wouldn't recommend it if you plan on actually driving the car.
Originally Posted by ZPower_123
When the exhaust pipes come to the rear axle why do thay have to bend up and over? why not just run it straight back under the axle ?
I have my x pipe set up right underneath my passenger side seat. It's a perfect fit. From there, the pipes bend to the center and dump before the axle. I have NOT SCRUBBED MY EXHAUST SETUP ONCE! It really is a great fit and sounds perfect...for me. Lots of guys put their x pipes in the dead center and get lots of scrub, but I haven't done it a single time. Just giving you an idea.
