XE230/236 114LSA Dyno numbers
Old 10-09-2003, 01:06 AM
  #16
Fastbird93's Avatar
Nice numbers!!!
Fastbird93 is offline
Old 10-09-2003, 01:28 AM
  #17
AndyB's Avatar
How come you went with a 114 lobe seperation on that cam? And where can I buy one
AndyB is offline
Old 10-09-2003, 03:12 AM
  #18
i387's Avatar
Where do I find these "XE" cams? I've looked through the CompCams catalog to no end, and all I see are XE-R aggressive lobe cams for the LS1. There are about 7 cams listed under the LT1 section - they are the Xtreme Energy type, but say nothing about the aggressive lobes. Are these the same?
Does anyone actually have part numbers for the LT1 XE cams?
i387 is offline
Old 10-09-2003, 05:51 AM
  #19
Jerm93z28's Avatar
ya just answered your own question, there, bud...
xe cams are considered to have "aggressive lobes" and alot of people complain about them being hard on the valvetrain. but you dont ever hear about people who actually run the cams having problems with the valvetrain. i ran my 230/236 with stock lifters and pushrods. no big deal.
jeremy
Jerm93z28 is offline
Old 10-09-2003, 07:17 AM
  #20
RealQuick's Avatar
The numbers are SAE. The correction factor was .99 and absolute barometric pressure was 29.95.
I ordered the cam at thunderracing and had it ground on a 114lsa for two reasons: emissions friendly and possibility of a power adder.
RealQuick is offline
Old 10-09-2003, 07:37 AM
  #21
Smoke T/A's Avatar
Originally posted by Aeromaks
my car setup will be about the same as yours....how is the daily driveability of it?
How much and how do i get in touch with Lloyd, regarding porting of the heads.
Email him at nighttrain66@msn.com
Smoke T/A is offline
Old 10-09-2003, 07:51 AM
  #22
93ZM6Tally's Avatar
I would also look at Combination Motorsports web site. They have a large selection of XE cams at good prices.
www.cmotorsports.com
93ZM6Tally is offline
Old 10-09-2003, 07:55 AM
  #23
NightTrain66's Avatar
Glad you are happy ith the results. pretty good #'s.
A 110-112 LSA would probably help the #'s a little but you are right, emissions would be slightly worse. With a cam that size, passing the emissions test will be tough anyway. If it does pass, the 114 LSA hekped quite a bit.
Good example of what a little tuning will do. 15-20 HP and a fatter the TQ curve is always a good thing.
NightTrain66@msn.com
NightTrain66 is offline
Old 10-09-2003, 08:26 AM
  #24
RealQuick's Avatar
Thanks for all the help with the heads Lloyd.
Old 10-09-2003, 01:04 PM
  #25
NiteRider's Avatar
Originally posted by Jerm93z28
that doesnt sound right at all, dude. me thinks you gots problems elsewhere.
jeremy
Sad isn't it but that's just how the 3200 series lobes are, they do not make power at high rpm's. The cam makes great power down low, fast, hard and very street able. On our dyno day one other person with a XE cam, larger one, had a similar power band where the cam just drops off after 6100 rpm. If reveing high and peaking at about 7000 rpm is what you want defiantly go with the magnum cam 3100 series lobes, might be wrong on the numbers.
NiteRider is offline
Old 10-09-2003, 01:48 PM
  #26
llafro's Avatar
If you look at the advertised duration numbers, you'll see why the XE series drops off at high RPM. The 0.006" lift duration on the 230/236 is a degree or two higher than that hotcam. They pack a lot of lift into the same duration, but there's not enough total duration to support high RPM. The Comp 306 also has 230 degrees of intake, but the advertised duration on it is 292 (vs. 282 for the 230/236)
I run Comp 987 springs, and the power does not drop off noticeably from the peak at about 6200. I took mine to 6400, and it was still making serious power.
If you want to rev, the 3300 series would probably be better. With the 3100 series higher lift lobes, you need more spring to comtrol the valves, and the lifters might not hold up too well to the added pressure.
llafro is offline
Old 10-09-2003, 03:53 PM
  #27
95 Silver TA's Avatar
IMO, For what you have done....Those Numbers Look GREAT!!
Thx,
Claude
95 Silver TA is offline
Old 10-09-2003, 04:13 PM
  #28
NiteRider's Avatar
llafro, your absolutly right, yes it acts like a hotcam at low rpm and it acts closer to it's own numbers when the rpm's go up. The lift numbers are quiet low, .510 .520 I belive on 1.5 rocker ratio!
With my new setup i'll be setting my rockers to 1.65.
Old 10-09-2003, 04:27 PM
  #29
Z95m6's Avatar
Nice numbers. I hope my numbers will be that nice when i finally hit the dyno.
Z95m6 is offline
Old 10-09-2003, 05:29 PM
  #30
Jerm93z28's Avatar
Originally posted by NiteRider
Well on my setup I was making 163.6 @ 6600 and 130.2 rwtq
i cant see you dropping 250rwhp running it up to 6600. shoot, i think i shifted mine around 6500! (tach was way off)
i even tapped my 7k rev limiter twice after missing a shift.
yes, i had this cam before. with a 3.42 gear, stock throttlebody, and self ported heads, i ran 7.98 @ 92mph in the 1/8. never ran it in the 1/4.
jeremy
Quick Reply: XE230/236 114LSA Dyno numbers
