which y pipe to get for Pacesetter
I just bought the Pacesetters. Which y pipe is best for the Pacesetter, which one doesn't leak etc? (the place I bought the headers recomended the Pacesetter y pipe)
thanks pat
thanks pat
Re: which y pipe to get for Pacesetter
Get the Pacesetter y-pipe to go with your Pacesetter headers. Since it is a slip fit, use some stepped band clamps for a good seal. I have both the long tubes and the y-pipe. They both tuck up very well underneath the car.
Originally Posted by pat35
are they good quality
IMO they are very good quality, but I have not installed them yet...
Here's some pics of mine:
The quality is pretty decent for what you pay, I second the band clamp idea, they will create a very good seal and will not distort the pipes like the regular u-clamps that will come with your kit.
Yeah, use the band clamps and the Pacesetter y-pipe should work fine. They hold plenty strong and you'll still be able to remove the y-pipe if you have to(like if you need to drop the trans).
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
