Yokohama's or Sumitomo's
Hey I was wondering which tires I should get for my car, the choices are.
Yokohama AVS ES100
or
Sumitomo HTRZ
I am looking for a replacement tire for my stock rims and both of these looked like good tires for the price. I am wanting the tire out of those two that has the best straightline traction that is the main factor. I know that a full slick or a DR would be better, but I already have a set of Nitto's that I am waiting to get some 15" drag rims to use, but in the mean time I need to pick a good tire for under $120 that will improve on my 2.4 60' times over the slick tires that are currently sitting under the fenders of my car.
Thanks alot.
Yokohama AVS ES100
or
Sumitomo HTRZ
Thanks alot.
so should I go with the Sumitomo's then I have heard good things about the traction with them. Like I said I am just looking for a good road tire that I can beat my previous 2.4 60' with until I get my Nitto DR's on.
Look into Kuhmo ecsta supra's. I have a set of 275/40/17's and am very happy with both straight line and cornering. Seem to be really good in rain too. I only have an A4 but 2.0 60 ft times are respectable. I believe they are reasonably priced also. Only complaint I've heard from others is road noise. I have not had any other tires so don't know about comparisons but these seem to hook really well even being a 40 series tire with little give in the sidewall. Check it out unless you have your mind set on the Sumitomo's.
Originally posted by danner
I would suggest the HTZRII - No complaints here, good wear, attractive tread pattern, good wet and dry weather traction. Sent you an email with a pic
