z28 center console question??
Do lt1 z28's not have a 1st gear on an auto shifter? On my auto 97rs vert, my shifter is P R N @ D 2 1. On the 97 z28 parts car i just bought with auto, the console doesn't have 1st gear.
Thank you for the reply. Yes according to the code, it did come with 2:73 gears, but the previous owner said, the first owner before him told him that he put new gears in being either 3:42 or 3:73. Said he can't remember for sure. If I keep my console with my 1st gear, will there be a 1st gear to use that way? If not, then I might as well use the parts car's console then, right? Thanks again.
Shawn
Shawn
You can just swap the plate that has the indicator in it. The shifter in the car with the 2.73s has a little plastic block on it that keeps you from pulling the lever into first. All you have to do is cut that block out with a sharp tool or hacksaw blade. It will then be like the "normal" shifter.
Originally posted by BigBlue95Z
What is the reasoning for that??? Or is that just the way they wanted it.....more $$ for the 3.32 upgrade to hold 1st?
F'n1996Z28SS
08-23-2023 11:19 PM
Bearmans
12-03-2014 05:28 AM
