300 lb Olympic weight set, with bench, pulldown bar, curl pad and leg press
Hey guys, I'm moving out of my apartment and I need to get rid of the weightbench that is currently residing where my kitchen table should be It's an olympic size bar with 300 lbs worth of weight, and the bar itself is 45 lbs. It has an adjustable bench for incline or decline, and has a leg press thing at the end of the bench. It also has a removeable pad for using a curl bar. The rack part where the bar rests also has a large pulldown bar, for doing chinup type exercises. Everything is in great shape, however the padding on the bench has some VERY small holes in it, my cat has claws that seem to poke through it once in awhile when she jumps on it. It is not shredded or torn in any way, just tiny little holes. I would like to get $225 for it, I paid twice that for it when it was new and barely used it. I'm located in Livonia near 7 mile and farmington. Thanks!
You can see the tiny holes in the surface from my cats claws, there are no tears though she never tried sharpening them on it, she would just jump up there and sometimes they would poke through because shes a fatass and her claws are massive
LS1 block and cat toys not included
If you still have this I am interested. Couple a questions though. How soon do you need it out? Can it all be broken down to fit inside a midsize SUV? Does it have a curl bar?
email me at mattbon@gmail.com
stockssn2o
05-25-2015 08:54 AM
99TransAmWS6
02-03-2015 08:27 AM
!!!TED!!!
08-27-2002 05:41 PM
