Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
anyone help me fix a coolant problem?
Old 09-01-2005 | 01:50 PM
1994TransAm's Avatar
hey guys,
i need someone to help me fix a coolant problem..
i'll pay for your time and give food and drink!!!
just help me diagnoise and repair...
call my cell 810-650-3359
car is in port huron...
it cannot drive.. only start and warm up....!!!
Old 09-01-2005 | 03:53 PM
joeSS97's Avatar
Re: anyone help me fix a coolant problem?
Describe it in detail and I will try to help from here.
Old 09-01-2005 | 04:34 PM
i'm losing coolant from my new 383...
-its not in the oil
-i've had the headgaskets changed and nothing as improved.
-car runs great only 300 miles on the engine
-lloyd elloit heads, dont think i'd get a bad set
- i did the rad. test and the pressure stayed high for almost 10 days... i just left the guaged pumped and it held there.
i'm using head studs...
i dont see smoke, no water in my cutout!!!
Old 09-01-2005 | 06:41 PM
joeSS97's Avatar
Seals on the coolant crossover tube?If not I would look at all the sparkplugs.If one looks unusually clean,thats where its going.How bad is it losing coolant?
Old 09-04-2005 | 06:41 AM
joeSS97's Avatar
So,what happened?If you dont see coolant on the ground or in the car,you have to face the fact that its going into the cylinder(s) and or oil.Even if you cant see it out the exhaust and it seems to run fine...Ever hear of water injection?
Old 09-04-2005 | 11:48 AM
triumph's Avatar
It holds the pressure test just fine. I think it had\has air pockets that need to be displaced. Steven
Old 09-04-2005 | 07:15 PM
limige's Avatar
how did you go about filling and bleeding the system adam? did you leave the cap off until the thermostat opened? bleed it after running some closed?
Magenta_Hearts
03-25-2015 10:24 AM
MattFick
02-15-2015 10:16 PM
94Z28LS1toLT1
01-15-2015 07:18 PM
AlaskaZ28
01-01-2015 12:30 PM
MislMan
07-19-2002 11:41 AM
Quick Reply: anyone help me fix a coolant problem?
