Anyone running ConvoPro rims, want to do some testing?
I have the 15x7.5 with a 5" bs. I have 26x10.5 ET Street, and same size ET Drag. After I get the 12 bolt in, I would like to experiment with different size tires. If you have the Convo rim & would like to meet at the track & do some experimenting, let me know. This would be after Woodward.
I suspect that I will be needing a larger tire once I am able to spray out of the hole, but would like to confirm that prior to buying new tires. Looking for 27 or 28" tire. Thanks.
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
hchap63@hotmail.com
10.88@124 (1.60)
I dont have the rear yet, still waiting, but I requested long studs, we'll see when they get here. Would I need spacers for those? I do not have my calipers ground, as they are not needed with the Convo Pros. Are they needed with the Welds you have?
Thanks Chad, but that wont work for me. I got the Convo so that I wouldn't have to grind the calipers. But if you ever take those off the rim to switch to another tire, then let me know.
3-15+, what size rim & back spacing do you have? Also the tire? Thanks.
BandDirector Blk98ZM6
02-20-2015 07:42 AM
