Anyone (Southern Ontario) thinking of going to Cayuga (TMP) this w/e??
I'm undecided still, but I'm thinking of going for either Friday night Test & Tune, or maybe Saturday T & T. Probably Saturday so there's more time to get more runs in and "play" with the car a little more! I planned on going last Saturday for F-bodies vs 'Stangs, but I did the gear swap instead?!
Pete you may not get too many TNT runs,its a Major Event weekend and its also a double points (sat&sun) bracket weekend.
Dave(Rock1501) and I will be there the following Sunday(25th),plus the TFBMS is having their event Saturday the 31st at St Thomas.
I should be at St Thomas at the end of the month as well.
Whoa! Good call! I didn't even think about this weekend! Yeah, I checked on their site, and it looks like Friday night will still be T & T, but Saturday and Sunday will be a write-off in terms of T & T I guess?! Then I guess that settles it! Friday night!
............................aww crap................all the Ricers show up on Friday's though.
............I guess I'll just have to kick their a$$!!!!!!
Just don't expect any traction Pete after they all drive right through the water box and haul all that water to the line
Make sure you post your results, there should be some new PB's with the gears
Yeah, I'm almost worried I'll have the same problem as my first time at the track last year, when I could only cut 14.1's?! That night was like Rice-a-roni fest, and there was water all over the starting area.
What I might try for now (until I can afford a set of slicks) is drop the pressure in the tires to maybe ~20 lbs and see if that helps at all? I just hope I don't run slower than 13.4?! I'd be a little P'd off!
kandied91z
03-03-2015 11:34 AM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
