Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
anyone wanna help my friend and i fix a lt1 $$$$
Old 05-29-2007 | 05:02 PM
1994TransAm's Avatar
hey guys,
i've been helping a friend try and fix his 94 z28 for over 2 years now and we have come along way..
new recent parts are
t56 swap..
new msd opti
plugs
coil
icm tested good at autozone
wires are fairly new
pcm is fine
i have injector pulses and fuel pressure... i just cant get spark at the coil.
coil reads 11.59 v when cranking and nothing higher. i have the pulsing ground and the wires from the coil to the icm both check out... as does the ground...
i need professional help.... will pay for gas and food,beer, and extra cash to get the car running. i have done the no start diag. test on shoeboxes site, i've tested the opti... everything works... what gives?
please call my cell at 810-650-3359 if you can help.... anyone ASE cert with scanners or tools would be greatly apperciated..
Old 05-29-2007 | 05:51 PM
FutureZMan's Avatar
how many miles on the car?
Old 05-29-2007 | 05:52 PM
IROC5.7TPI's Avatar
Crank sensor?
Old 05-29-2007 | 07:49 PM
IrocSS85's Avatar
no crank sensors on 94. obd1 remember. hmm, so you got power and ground at the coil? i'll have to look at a manual to see what your supposed to have at the opti and so on. what about the harness that goes from the opti to the main harness? in good shape? sure the terminals are not opened up/spread? in that case you c ould have power and ground there, but not making contact with teh pins in the opti.
Old 05-29-2007 | 08:14 PM
FutureZMan's Avatar
Originally Posted by 1994TransAm
hey guys,
t56 swap..
new msd opti
plugs
coil
pcm is fine
phone died sorry man >.<
rideordie
11-05-2019 04:52 PM
10-31-2016 11:09 AM
Brake_L8
01-20-2015 09:44 AM
Jrlt1
01-03-2015 07:38 PM
MislMan
07-19-2002 11:41 AM
Quick Reply: anyone wanna help my friend and i fix a lt1 $$$$
