Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
f/s custom ford 9" axles for 82-92 camaro
Old 02-02-2005 | 11:50 PM
1BAD86Z's Avatar
I have a set of moser 31 spline axles for a 9" in a camaro, firebird, trans am. bearings are pressed on and are 3.8 od. for a early big ford housing end. $175.00 firm, If not sold in 1 week they will go on ebay. Call Scott K. @ (586) 630-1098.
Old 02-06-2005 | 09:48 PM
WECoyote's Avatar
Question Re: f/s custom ford 9" axles for 82-92 camaro
Interested in these axles. Are you sure the bearing OD is 3.8" and not 3.15"? I don't think I have ever heard of a 3.8" OD bearing for the big Ford axle housing ends. Also are these axles meant to be a direct bolt in for the Moser Ford 9" 3rd gen housing or were they built to intall in a converted 9" housing? Do you have the bearing retainers (horse shoes)? Let me know. Thanks!
Mike
Old 02-06-2005 | 11:13 PM
1BAD86Z's Avatar
Hi Mike, sorry you are right they are 3.150, I measured wrong. These are out of my moser 9" in my 1986 camaro stock width. I purchased 35 spline axles and a spool and i did get a new set of retainers but i reused my old ones. If you buy these I will include the newer retainers. thanks Scott K.
Mike
Old 02-07-2005 | 06:32 AM
WECoyote's Avatar
Hey Scott I'm still interested. How many miles do these axles have on them? What kind of useage have they seen (slicks, etc)? Were you running a spool with these axles or a locker or ?
Got pics you could send?
How much to ship to 53551 and by what means? i.e. UPS, FedEx, etc.
Let me know. Thanks again!
Mike
Old 02-07-2005 | 11:08 AM
1BAD86Z's Avatar
The axles have seen about 12,000 miles on them, the bearings are in excelent shape. I had a detroit locker when i first put the axle together. Then got heavy into drag racing, they have seen 900 hp passes going 9.89 at 143mph. I have no studs in them, i put then in the front rotors when i bought my 35 spline axles with 5/8's studs.
The splines look near new they show very little wear for what abuse i have put them through, just trying to be honest not trying to scare you away.
I will get some pics later if you are still interested, and let me know if you need any more axle parts I am a dealer for Moser and can get a housing for less than anyone else. Scott K.
F'n1996Z28SS
08-23-2023 11:19 PM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
CaRParts102
12-06-2014 08:45 AM
NewsBot
12-03-2014 12:30 PM
Quick Reply: f/s custom ford 9" axles for 82-92 camaro
