Guys running slicks, got a few questions.
I am going to try the 28x10.5x15 ET drags for the first time tomorrow night but have some questions.
My tires are on a 15x8 rim and are screwed to the rim, so I believe that they have tubes in them but am not sure since I bought them used. I went to put air in them today and got them up to 10psi but they are rock hard.
How do I know if I have tubes for sure?
The tires shouldn't look flat when they are on the car should they?
Also do you have any pointers on launching?
Thanks.
Chad Beebe
'97 T/A WS6 M6 Dark Metallic Green
CC 306 cam and some other stuff.
My Car
12.762@109.13 with 1.828 60'
Best 60' 1.816
Thanks.
Chad Beebe
My Car
Best 60' 1.816
Location: windsor,ontario,canada Home of the fastest LS1 and LT1 6-speeds :D
Hmmm 10 psi and rock hard? Are you sure that the gauge is ok? 10 psi will be fairly soft, with bit of a bulge.
You can see if you have tubes by the type of valve stem, a regular valve stem is tubeless and a threaded valve stem is on tubes.
Launching will depend on transmission, clutch, power level, rearend etc etc.
With an M6 you need to get 1 to 1.5 revolutions off the line to save your clutch, so you'll need a spotter.
Enjoy,
Roman
Enjoy,
Roman
<font face="Verdana, Arial" size="2">Originally posted by romanss:
Enjoy,
Roman</font>
Enjoy,
Roman</font>
The gauge is brand new, so I believe it is okay.
When you say threaded, do you mean the valve stem is threaded into the rim?
Thanks.
Chad, what I mean is that the entire length of the valve stem is threaded so that you can thread a nut from the outside to keep the valve stem from disappearing into the rim.
Chad,
You would'nt by any chance be related to any of the Bebee's up in the St.Johns area would ya??? My grandma used to be a Bebee. Just curious.
James
91 Z-28 Convertible 305 H.O. 210 RWHP
crane hi-6,holley reg,air foil,3:73 richmonds,Ed Wright stage 2 chip,msd wires,SLP headers,best e.t 14.4@99.02mph
91 Mustang 5.0 LX Convertible. A4, FMS 9mm plug wires, Denso Plugs.Best E.T. 16.097 @ 86.89mph.Best 60 ft 2.4
(Retired 1995 S-10 Blazer 4X4, 230,000 Mi
Leland RD burnout Champ!!!)
James
"I've gotta brother!!!" LMAO
Chad, If those tires dont work out, you can always donate them to science. I'll put em to the test
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
hchap63@hotmail.com
10.88@124 (1.60)
Roman,
Yes the entire outside of the valve stem is threaded. With the 10psi in them they felt hard but once I put them on the car and let the car down they did squat pretty good. I was unable to run them last night because I didn't grind enough off the brake caliper and the wheels were rubbing after I torqued the lugnuts.
James,
Most of my Beebe relatives are from the Flint area. Growing up in Chesaning there were only 2 Beebe families (mine&grandparents) but once I moved down to Portage there are tons of them.
Harold,
I plan on using the tires at M7 and then I will probably sell the slicks and skinnies to get a different style of rims. These Welds with that thick center hub are a pain. Even with the longer ARP wheel studs in the front when I put the spacers on the studs are just flush with the outside of the wheel.
Chad Beebe
My Car
12.691@111.90 with 1.955 60'
Best 60' 1.816
James,
Harold,
Chad Beebe
My Car
Best 60' 1.816
Chad,
Wow.;You grew up in Chesaning?? I spent a little time over that way.My ex girlfriend lives over there.She had 2 older sisters too.What year did you graduate??
I went to school at Ovid Elsie. Not too far away.Small world.
James
James
<font face="Verdana, Arial" size="2">Originally posted by 91 Redd Sledd:
Chad
Do you know any of the Hovanecs from Chesaning????</font>
Chad
sleeperZ96BT
09-05-2002 05:45 PM
