Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
looking for a stall conv. for a TH400
Old 06-11-2003 | 10:15 PM
IrocSS85's Avatar
I am thinking about geting a TH400 for my Iroc. I can get a good deal on one from a friend, but I still would need a conv. for it. I found one online for $180 new, but that one isnt to be used w/nitrous. so If I can get one for cheaper then that, i might just go ahead and get the 400 w/trans brake and manual valvebody.
chris
Old 06-12-2003 | 09:42 AM
Pro Stock John's Avatar
I got a few buddies in Chicago with some for sale, 3500 and 4500, ~$300 and $350 each.
Old 06-12-2003 | 09:49 AM
Black Sunshine/ 00SS's Avatar
I doubt you are going to get what you are looking for for under $180. You are going to get what you pay for. I got mine from Rapid Motorsports, in the $700 range. Will run around 3600 off the juice, and 4400-4500 on the juice.
You could probably find a decent one in the $400 range. Look in Summit or Jegs. Good luck.
Old 06-12-2003 | 01:08 PM
TheNovaMan's Avatar
If I were to build a slushbox, I'd definitely use a trans brake!
Old 06-12-2003 | 02:00 PM
Redbird's Avatar
Arrow Try these guyz.
www.edgeracingconverters.com
$490.00
These are the guys I just bought mine from last spring. Talk to ANDRE and tell him Kevin Hinkley From MI sent ya! They will build you EXACTLY what you want.
HInk
Old 06-12-2003 | 02:05 PM
The ones I mentioned are used:
JW 4500, $300 used one season it
JW 3500, $350 used maybe 5 passes it was too small
Nayr
03-03-2023 08:34 PM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
greenzee28
09-25-2015 04:29 PM
damnyankee36
09-09-2015 07:06 PM
94ZinEdgewater
09-08-2015 09:55 PM
Quick Reply: looking for a stall conv. for a TH400
