Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Need a certified mechanics help.
Old 09-24-2004 | 08:09 PM
POSSESSEDZ's Avatar
My work car quit on me today. Its a chrysler concord 3.5L . Iam getting no spark, I put in new coil pack, wires, plugs and camshaft sensor. Still no spark what else can i try. Thanks, Dave
Old 09-24-2004 | 10:27 PM
Dave89IROC's Avatar
Re: Need a certified mechanics help.
what year?
Old 09-24-2004 | 10:32 PM
IrocSS85's Avatar
well I have zero exper. with chryslers, but there's always a crank sensor and ign. module. also, you need to make sure you have power at the ign. module and coill as well as a good ground.
good luck
chris
Old 09-24-2004 | 10:39 PM
POSSESSEDZ's Avatar
Its a 1994
Old 09-24-2004 | 10:41 PM
POSSESSEDZ's Avatar
also what if the timing belt broke would you still get spark if every thing else was working before it broke.
Old 09-24-2004 | 10:44 PM
Dave89IROC's Avatar
good luck
chris
chryslers havent use ignition modules in quite a while, coil/coil pack/s is/are controlled direct from PCM
Old 09-24-2004 | 10:50 PM
IrocSS85's Avatar
ok i want to change my answer. pcm. lol
Old 09-24-2004 | 10:51 PM
Dave89IROC's Avatar
OK, you will have spark without a cam sensor signal, cam sensor on DCX cars is pretty much for fuel sync only(ignition is coil pack, waste spark type)
ok, just to rule it out, on the pass side of the motor at the front, pull 4 or 5 10mm head bolts from the top of the black timing belt cover and bend the top to the front and have someone crank it, you should see everything turning
can you hear the fuel pump prime?(FP relay is powered by the ASD relay, which powers the coil pack)
do you have access to a scanner that will hook up to it?
Old 09-26-2004 | 09:33 PM
smiley23's Avatar
Have you checked the codes yet?
Click the key to the "run" position 3 times and the SES light on the dash should flash he codes.
Not sure if you have ever done this before - so I add this example to follow:
2 short flashes (2 second pause) and 1 short flash = code 21
Long pause
Code repeats itself
Long pause
Next code
Old 09-27-2004 | 04:45 PM
POSSESSEDZ's Avatar
It was the timing belt. Man what a pain in the *** to get the dampner pully off. spent 2hrs getting that thing off. Thanks for everones help.
Old 09-27-2004 | 05:05 PM
Dave89IROC's Avatar
actually, it is just barely possible to get the new belt on with the lower pully on
I hope you put a new water pump on when you had it apart
Kinglouui
05-26-2016 11:05 AM
David Dempsey
03-12-2016 12:42 AM
truecontr3
10-11-2015 09:30 AM
surreybrad
09-29-2015 09:00 PM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: Need a certified mechanics help.
