Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Oil pump assembly
Old 04-06-2005 | 12:43 PM
CamaroBoy96Z28's Avatar
Oil pump assembly
Well everything is going back together on my H/C swap. I got a Melling M155 pump, pickup, and driveshaft. Basically I'm looking for either a machine shop that can press in the pickup and set it to the correct depth or any tricks so that I can do it in the comfort of my garage. Any suggestions would be greatly appreciated...have to get the car on the road!
Old 04-06-2005 | 10:13 PM
OneBad98Z's Avatar
Re: Oil pump assembly
i have installed the pickup tubes with some gentle persuasion with a open end wrench that is just the right size to fit over the tube drive it home hittting the wrench with a hammer believe it or not its not that tight of a fit. you may opt to have the pickup welded to the oil pump housing though. as far has height of the pickup i like to see the pickup about 1/4 to 1/2 off the bottom of the pan. some people have different opinions on this..
Good Luck
Greg
Old 04-06-2005 | 11:12 PM
Good Luck
Greg
Thanks I'll give the wrench a try. What method of pan to pickup clearance measurement do you generally use? Putty/Play-doh or another method?
Old 04-06-2005 | 11:16 PM
Mike94ZLT1's Avatar
As mentioned, get it welded just to be safe!
Old 04-07-2005 | 12:16 AM
triumph's Avatar
Scott call me i will walk you thru it. Steven 313-617-6637
Old 04-07-2005 | 01:57 PM
Steven, I'll call you sometime this evening...the pump is one of the things I want to get done today.
Old 04-07-2005 | 07:29 PM
triumph's Avatar
Scott......you didnt leave me a # to call you back. Steven
Old 04-07-2005 | 11:16 PM
Sorry about that...too excited to get my car done I guess.
PS: You have a PM.
HectorM52
07-30-2017 11:46 AM
DirtyDaveW
03-15-2015 07:01 PM
carl.froehlich
03-13-2015 12:38 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
Quick Reply: Oil pump assembly
