Redbird has juice going into the intake!!! YE-HA!
Only problem was the too small of a fuse in the hot lead to the relay.
Figured a way to test since I have a window switch to turn on/off the N2O. I had Sue get in and hold the rpm ABOVE my ON rpm module.
I hit the throttle activation switch and
bam-O, RPM's raise without moving the gas pedal, plus I could hear the switches clicking! Tested BELOW the ON RPM and no solenoid activation!
Have 3 ways to dial the car/N2O in to hit the 12.00 number:
1) N2O/fuel jetting changes.
2) On/Off points of N20 activation using the window switch and different RPM modules.
3) Shut system down at lock-up point of converter if needed or run through lock-up if needed!
Hoping to give TAJACK some competition in the 12.00 (G-EFI) class. Got a feeling as I have her set up now, she may run some 11.8X's. I'll be there early to get some time runs before qualifications.
Hoping a 50 hit will net me some low 1.5X sixty foot times, as the nitrous will hit right at convertor stall point, yeah baby... 50 more ft/lbs of torque at launch!
I'M READY (I hope)! I'M JACKED NOW!!
HInk
[This message has been edited by Redbird (edited September 05, 2002).]
BOY... I know I would be afraid to look to see if you have a target on your a#*
I bet it's just a big ol' zit with a head on it!!
Now... concentrating on sub .550 lights!!
I CAN DO IT... I CAN DO IT!!!
HInk
HInk
You'll be suprized if you think yer only getting an extra 50ft-lbs at launch! Ya might get a bit more depending how low/high your stall is. I remember you saying something about a 3200 piece but i'm probably wrong. See ya there!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Denny Villemure
www.denny.cz28.com
Kev good deal on getting your N20 going.
Kev please don't talk about Jacks back side. Not something I want to think about.
87 IROC L98 700R4 A few mods. Best et 12.96 at 110 mph
All motor No NOS or Supercharger.
96 WS6 FORMULA Best et 13.5 at 105 mph
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
congrats hInk, you guys crack me up!
MY car featured:
www.bmrfabrication.com.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.14@135.11mph N2O(no more excuses )
Best 60' 1.375
Best mph: 135.11mph
oh yeah also an 80 Camaro, an 98 Ram Sport, the latest addition a 94Z28, w/T-Tops!
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
MY car featured:
11.36@120.35mph, NA
Best 60' 1.375
Best mph: 135.11mph
P.J.
Redbird
08-13-2002 03:29 PM
