Thanks Roman and Randy!!! car is ready for a cruise to T.O. :)
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
car is running, whew! i have to be up in 3 hrs to drive... the car to toronto for work, this way i can get some clicks on it. trans and clutch went in fine, until i turned the key! mcleod sent a complete new pressure plate, it had studs for arp nuts to bolt it up. the last one i had only had bolts, well when i cranked the motor the i felt and hear some bad noises..... hmmmm ended up being the fork was hitting the top of the studs
so pull the trans again and yank out fork and whip out the grinder, i notched them put back the trans, thanks to Roman and Randy!!!!! and away we went, Roman also tracked down some bare wires causing a fuse to keep blowing.
went for a drive and wow i have a clutch that grabs way down low now, and i mean it GRABS!
i also had to get a new drive shaft built, i twisted the spline in the spicer chromoly yoke... AGAIN! on with the billet Strange slip yoke. i hope i don't twist these splines, after this weekend i plan on yanking the shaft and having the slip yoke cryogenically frozen like i did to the trans parts.
well g'nite to all! only thing left other than goin' back to race mode is bigger jets... don't worry Roman I wouldn't let you go into "uncharted territory" alone
any of you guys goin to grand bend this weekend? if so c u there!
bring on windsor day!!!
MY car featured:
www.bmrfabrication.com.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.14@135.11mph N2O(no more excuses )
Best 60' 1.375
Best mph: 135.11mph
oh yeah also an 80 Camaro, an 98 Ram Sport, the latest addition a 94Z28, w/T-Tops!
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
MY car featured:
11.36@120.35mph, NA
Best 60' 1.375
Best mph: 135.11mph
P.J.
Location: windsor,ontario,canada Home of the fastest LS1 and LT1 6-speeds :D
No problem Taner.
I hope that this will be the last time we ever have to pull a transmission out twice in one night.
Now to go and thrash on mine to get it done.
car ran great, i was leaving the plant in concord when some farkin" emissions bastard pulls me over, go figure. oh well got a f'n fine to pay now!
it is so hard just gingering the car around, lmao!!!!!
ChrisFrez
11-23-2014 10:33 AM
