Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Wanted to buy....
Old 05-31-2003 | 09:34 PM
KGRESOCK's Avatar
Wanted to buy....
Need a LT1 T56 bell housing
And Msd window switch pills 3000,6000,6200
Kevin
Old 06-02-2003 | 10:13 AM
97WRAITH's Avatar
Hi Kevin how's it going did you get everything sorted out yet?
Rob.
Old 06-02-2003 | 01:39 PM
KGRESOCK's Avatar
Rob,
The good news is.....by the time your ready to do yours I'll be able to do it in my sleep.
The bad news.....going to send the assembly back to Mcleod to
check it out.
1. The flywheel has no weight( should according to Mcleod)
2. The secondary clutch is not properly contacting the intermediate plate. The wear pattern suggests the clutch is
"bowed"
Good news I slipped the stocker back in and have started the break in process on the 12 bolt.
Hopefully by the time I have the rear broken in the clutch will be back.
Have you been out yet and how are you running?
Kevin
10-31-2016 11:09 AM
ModdedNerd
02-05-2015 04:37 AM
ChrisFrez
12-21-2014 09:47 PM
ModdedNerd
12-14-2014 10:28 AM
Quick Reply: Wanted to buy....
