****Free Nitrous Kits And Accessories****
FREE Nitrous System!!!
Nitrous Outlet wants to give you a FREE Nitrous System
Do you want a FREE Nitrous system? If you participate you could end up with a FREE Nitrous System in no time.
That’s right I said FREE… . Nitrous Outlet will be giving away FREE Nitrous Systems and Accessories on the first of each month. The item we are giving away will change every month.
HERE IS HOW.
It is very simple and will only take a moment of your time.
All you have to do is put a catchy slogan and a link to our website in your signature.
Example:
When Speed Counts
www.nitrousoutlet.com
or
Your #1 Nitrous Source
After you add link in your signature simply make a post back here telling us how much you would like to win our FREE give away.
Each month we will pick a winner and post the results. We will keep it within this same post and just keep updating the information. This way once you post you are always entered in to win as long as the link remains in your signature. The winner will be chosen by drawing.
We are going to kick this program off by giving away a Brand X Single Nozzle Nitrous System. We will be giving this system away on March 1st.
Brand X Nitrous Systems are designed for the fuel injected enthusiast looking to add reliable horse power gains up to 200 hp. All Brand X Systems come with the following Components.
1. Black 10lb bottle with high flow 90 degree valve.
2. Stainless Steel quick release style bottle brackets.
3. Small body solenoids rated up to 200 hp.
4. 1/16 wet nozzle or 1/16 dry nozzle
5. 1/16 nozzle adapter
6. Jetting up to 150 Hp.
7. 16ft Main feed hose.
8. 2ft supply hoses to nozzle
9. Relay with Harness
10. WOT. Switch and bracket.
11. Bottle nut.
12. Bottle nipple.
13. Universal solenoid brackets.
14. Solenoid fittings.
15. Wire.
16. Hard ware pack.
17. Electrical pack.
Good Luck.......
Thank you for your support!
P.S. feel free to post a link to this thread in any of the other sections of this board or an other place that might be interested.
HERE IS HOW.
Example:
When Speed Counts
or
11. Bottle nut.
12. Bottle nipple.
15. Wire.
16. Hard ware pack.
Good Luck.......
Im always up for free stuff, I was going to buy one for my new build, 383 JE nitrous pistons, compstar rods and crank, was planning on nitrous So will see what happens
Rebuilding my ride, with new short block filled with speed pro pistons, gapless rings. balanced. Arp bolt package, Comp Cam 305, Roller rockers 1:6, bee hive valve springs, heads and intake are gasket matched. Full MSD igntion ready to go. Why would I skip the NOS? I din't plan to build this to finish second.
http://www.nitrousoutlet.com/index.asp
