Autolite 104's installed - now it's surging badly!
Old 07-20-2002 | 09:39 PM
KASR_Z28's Avatar
Angry Autolite 104's installed - now it's surging badly!
I installed the autolite plugs in anticipation for the dry kit, but now the car is surging horribly - the idle is rough as hell and it acts like it's bogged during WOT!! WTF is going on??? Anyone???
I haven't installed the MSD 6S yet, will that solve the issue???
(I put this LT1-Tech just in case anyone outside of N20 has a clue what this could be...)
KASR
94 Z28 Hardtop - (stock: 10.5:1, 5.7L, rated 275hp@5200, 325lb@2400, MFI - Current Rating: ???)
Throwing money at the hungry beast and moddin' away like a mad-man =) Holley CAI, !TB, !MAF, Flowmaster Catback, Monza Quad Tips, 3" cutout, 3.23 gears GU5/G80 perf. axle, QLC, 4L60-E, Spectre Breather and Filter, Autolite 103 plugs, wires, and filter, MSD 6A MODS TO COME: Jet-Hot Hooker Long Tubes, Yank 3000 TC, cc305 cam, 1.6 rockers, NX Gen II
Old 07-21-2002 | 12:25 PM
n2oTransAmLT1's Avatar
Post
Check your wires really good. My car will occasionally surge. I get out push on all the wires on the plugs and it goes away. I guess one of my wires, still not sure which it is, must not make perfect contact all the time with the plug. Also, make sure all the plugs are in tight enough to seal. Im not sure if the gap size would cause surging or not. Im assuming it doesnt since I have run plugs gapped from .055 to my current .032(roughly) with no problems but minor surging sometimes which has always been since I got the car. Then there could alway be a burnt wire, but probably not the case if it just all the sudden started with the new plugs. Hope this helps a little.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Old 07-21-2002 | 01:00 PM
KASR_Z28's Avatar
Post
Tried to take it back to the place that installed and they were closed! Argh!
I did notice that it gets real bad around 2500+ RPM and jumps all over the place - keep in mind this did not happen till they installed the plugs - b@stards!
I'll check the wires for snug fit and make sure the plugs are in all the way....still going to take it by. Any other thoughts on this?
KASR
Old 07-21-2002 | 05:52 PM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Exclamation
Well, just another Autolite problem!
That's why I keep telling people they are junk!
I even went as far as to take the first set I bought of them back to NAPA and demanded my money back. They gave it to me and I bought some NGK's and never looked back.
My car wouldn't even start with the autocraps, so at least you're a little better off.
By some NGK's and put them in yourself and give those 104's to your competition.
Good luck
Dave
If a little's good,
More is better,
And too much is just right!!!
Old 07-22-2002 | 01:40 PM
KASR_Z28's Avatar
Post
ARGH!!! I take the car back and it turns out the monkey-brained mechanice at Hibdon's didn't plug two of the wires in and plugged another into the wrong plug! SheesH! He also didn't gap them the way i asked - but when I took it to a different Hibdons they were cool and hooked me up correctly - car runs great now - installing the ignition on tonight....thanks God!
KASR (who is next time, installing the plugs himself!)
Noenav
03-01-2019 07:38 AM
grgguy
17
02-23-2015 07:57 PM
blac94Z
02-23-2015 04:29 PM
97Z28Muscle
02-06-2015 10:44 PM
dirtybird81
10
01-06-2015 09:31 PM
Quick Reply: Autolite 104's installed - now it's surging badly!
