CC305 cam with nitrous
Does the cc305 camshaft work well with nitrous? I'm thinking of 150-200 shot. Will this much nitrous be too much for a stock bottom end? BTW the engine is from an impalla SS 96' I believe ( currently in my car). I want the car to sound almost stock, which will be a task with Long tubes and true duals, while being able to kick some serious ***-falt, and have good gas milage.
(Project Sleeper)
(Project Sleeper)
I run the cc305 cam. Does not sound stock when the cut out is off. Very definative lope. It seems to react well to the juice to. I've hit it with 150 a few times with no problems, but I am a forged bottom end.
My set up exhuast wise is pacesetter headers though an off road pipe to a cutout or through the stock muffler. With the stock muffler on you can still hear a lope, but not too loud of one. The muffler kills it for the most part unless you listen for it. I'm 11:1 compression too. I have heard that makes you louder. I don't know if that is true or not though.
snksknr94
08-02-2002 07:31 PM
