Dry nos system
Dry nos system
Question for you that run dry nos systems. Just got 30lbs sov injectors in but could not use gm clips on them. On a dry system the rail presures go to about 90 ibs because the return line is close at the reg. Have any one of you had the injector push the injector out of the rail without some way to hold the injector in place? thanks for your replys.
Re: Dry nos system
With my past dry NOS set up, my fuel pressure regularly spiked to over 90psi and I ran my 30lb svo injectors for almost 6 years without the clips and they never leaked , came out or anything......should be fine without the clips, just make sure to have an "even" amount of injector insert into the manifold and the fuel rail......
