1997 Z28 M6 63k Miles, Tons of Modds
Old 10-11-2011 | 02:50 PM
HarleyZ28's Avatar
Recently purchased my new 1997 Z28 M6 Camaro. Car has 63k Orginal Miles, One Owner Car, Garage Kept, Like brand new inside and out. Car is beautiful.
Modds:
Engine:
- Stock 63k mi bottom end LT1
- Manley 2.0 intake/1.60 exhaust valves, Crane 10308-1 spring kit,
- GMPP Hotcam
- GMPP 1.6 ratio aluminum roller rockers
- Comp Cams hardened pushrods
- Cloyes double roller timing chain
- Hypertech 160 deg t-stat
- CSI electric water pump
- March 25% underdrive pulley
- 1LE a/c delete pulley
- red powder coated intake manifold
- Lucas/Delphi 42 lbs / hr injectors
- Walbro 255 lph fuel pump
- MSD Blaster Coil, new MSD opti cap/rotor
- Taylor Spiro Pro 8mm wires, NGK TR55 plugs
Intake/Exhaust:
- SLP LS1 lid conversion with ls1 upper radiator shroud
- Stock TB, Hypertech airfoil, TB coolant bypass
- PCMforless hotcam programming, 180 deg fan setting, 6500rpm rev limiter. Deleted: EGR/AIR/CAGS/CPS/rear O2's
- SLP 1-3/4" midlength headers/ypipe. Stainless steel, Jet Hot coated
- Borla exhaust with DMH remote electric cutout
- Cat removed, bullet muffler in its place, also have single cat or cutout that will bolt in easily if wanted.
Trans/Rear:
- Stock T56, B&M Ripper Shifter. (Trans shifts and feels as good as it did new)
- Lingenfelter 3.5" aluminum driveshaft, spicer yoke & 1350 rear joint
- Moser 12 bolt, 4:10 gears, 1350 pinion yoke, Eaton posi, 33 spline axles, aluminum support cover & preload studs.
(very strong rear with very little gear whine)
Suspension/Wheels & tires:
- Energy Suspension Poly: front & rear sway bar bushings & end links, trans & engine mounts
- BMR strut tower brace
- Spohn body mounted TA & DS loop, BMR adjustable panhard bar, UMI adj LCA's, Comp Eng. welded SFC's
- LS1 brakes/slotted & cross drilled rotors, line lock. Rear: stock/Hawk HPS pads
- C5 Vette silver Y2K thinspokes 17x8.5 / 18x9.5
- Kuhmo Exsta MX 245/45/17 (75% tread), Nitto Drag Radials 305/40/18 (25% tread)
- Original springs, new rear shocks just installed
Old 10-11-2011 | 05:41 PM
Re: 1997 Z28 M6 63k Miles, Tons of Modds
Welcome to CamaroZ28.com!!!
Looks super clean, and sounds mean. I always wanted a silver car, but never bought one.
Old 10-12-2011 | 06:05 PM
TedH's Avatar
Sharp looking car. Welcome to the site.
Old 10-13-2011 | 09:15 PM
Camaro2SSRS's Avatar
Nice looking car! Welcome to the site!
Old 10-15-2011 | 10:20 PM
JasonD's Avatar
Admin Emeritus
Welcome! Betcha that thing flies!
Old 10-16-2011 | 06:57 AM
AL SS590 M6's Avatar
Moderator
ScottZ
03-03-2004 02:34 PM
turbo_Z
08-19-2002 11:50 PM
DubbyZ28Camaro
08-04-2002 01:53 PM
30thZ286speed
08-03-2002 05:54 AM
Quick Reply: 1997 Z28 M6 63k Miles, Tons of Modds
