car only starts on starting fluid then shuts off
Hi my name is Mike, I just recently got a 1994 Camaro v6. It has always had a little hesitation to it since I got it. But I was backing up the other day and it started shaking really bad and shut off but it started right back up and I was able to drive it home. Needless to say The next morning I went out and all it did was crank. So I put on a new fuel pump and fuel pump relay, I have checked all the grounds ect. its getting fuel if I prime the line with the valve. The only way it will start is with starting fluid and then shuts off again. Does anyone know what else I can try?
Re: car only starts on starting fluid then shuts off
Welcome to CamaroZ28.com!
"New Member Intro" isn't the best place to get tech advice. I'm going to "copy" this post to "General 67-02 F-Body Tech".
https://www.camaroz28.com/forums/gen...-94-v6-878440/
fpete1992
12-11-2014 03:51 PM
