Had a small engine fire, need a bunch of stock parts
I had a small engine fire about a month back and I am now in the process of getting the car back up and running. a lot of the rubber and plastic parts on the engine were damaged so here is the list of what I am currently looking for
-Throttle cable
-engine wire harness
-the plastic cover that goes under the passenger side corner of the bumper
-Mass Airflow Sensor
-Intake Air Temp sensor in the Rubber intake elbow
-Coolant temp Sensor in the side of the head
-MAP sensor in the intake
-Low Coolant sensor in the rad
-Rad Drain plug
-Plastic Rad support (Piece at the front of the engine bay that holds down the top of the rad)
-Window wiper washer line from the tank to the sprayer in the cowel
-Plastic cowel that goes across the bottom of the windshield
-Everything Vacuum related that is in the engine bay
-All of the rad hoses minus the heater hoses
-Wires from the body harness going to the rad fans cut as long as possible
-Wires from the body harness to the Low coolant sensor on the rad cut as long as possible
-Horns
-oil pressure sender on the back of the block
-Low Oil sensor from the oil pan
I would prefer to buy as much if not all of this stuff from one person to save on the shipping costs.
My Email is Mikeschreiber@shaw.ca
-Throttle cable
-Rad Drain plug
-Horns
Re: Had a small engine fire, need a bunch of stock parts
-Throttle cable
-Rad Drain plug
-Horns
-Throttle cable
-Rad Drain plug
-Horns
-Throttle cable-no
-engine wire harness-no
-the plastic cover that goes under the passenger side corner of the bumper-yes 20$
-Mass Airflow Sensoryes40$
-Intake Air Temp sensor in the Rubber intake elbowyes15$
-Coolant temp Sensor in the side of the headno
-MAP sensor in the intakeno
-Low Coolant sensor in the rad yes10$
-Rad Drain plugyes5$
-Plastic Rad support (Piece at the front of the engine bay that holds down the top of the rad)no
-Window wiper washer line from the tank to the sprayer in the cowelyes10$
-Plastic cowel that goes across the bottom of the windshieldyes25$
-Everything Vacuum related that is in the engine bayno
-All of the rad hoses minus the heater hoses no
-Wires from the body harness going to the rad fans cut as long as possiblei will send a whole body harness cut at fire wall40$
-Wires from the body harness to the Low coolant sensor on the rad cut as long as possiblesame as above
-Hornsyes10$
-oil pressure sender on the back of the blockno
-Low Oil sensor from the oil panno
175 in merchandisebeing your in canada and cowl parts are a little big how is 200 shipped
here is what i have
-Throttle cable-no
-the plastic cover that goes under the passenger side corner of the bumper-no
-Mass Airflow Sensor-no
-Intake Air Temp sensor in the Rubber intake elbow-no
-Coolant temp Sensor in the side of the head-YES, 10 bucks
-MAP sensor in the intake-YES, 20 bucks
-Low Coolant sensor in the rad-no
-Rad Drain plug-no
-Plastic Rad support (Piece at the front of the engine bay that holds down the top of the rad)-no
-Window wiper washer line from the tank to the sprayer in the cowel-no
-Plastic cowel that goes across the bottom of the windshield-no
-Everything Vacuum related that is in the engine bay-YES, not all but will do the brake booster line for 5
-Wires from the body harness going to the rad fans cut as long as possible-no
-Wires from the body harness to the Low coolant sensor on the rad cut as long as possible-no
-Horns-no
-oil pressure sender on the back of the block-no
-Low Oil sensor from the oil pan-YES, 15 bucks
70 dollars Shipped for all this. let me know
-Throttle cable-no
-Rad Drain plug-no
-Horns-no
