High Capacity/High Flow Radiator
Looking for a high capacity or high flow radiator for automatic 93 z28 camaro - getting 383 motor and wouldnt mind a better coolant flow - any suggestions on where to get one ... looking for something reasonable - i am expecting to pay over 200 for it but cant find a place that sells what i need......thanks
Re: High Capacity/High Flow Radiator
You won't find a direct replacement like you describe for under $500.
I found a Howe all aluminum radiator that was considered a direct replacement for an LT1 equipped F-Body and it was closer to $700. It was for a manual trans ...
The problem is reverse flow cooling, placement of radiator hose connection, their size, and the 2 other connections from the TB and water pump (oil cooler option).
Just not a lot of call for this type of thing ...
carguyshu
01-22-2017 11:19 AM
01-23-2015 01:13 PM
