? About 3M SMR & Zaino
Got some parts painted, put them back on the car, and then took the car back to get the parts wet sanded. I noticed a couple days after I got it back that there were some scratches. I applied Z5, even though the 3m was suggested here, just to see what it would do to them. The spoiler looks fine, but the top part of the rear bumper, the part you could theoretically sit on, looks bad in certain light. It looks like it has horizontal scratches completely across the surface, and in a few places, up near the tail panel, there are places that look dull in certain light, kind of hazy like a smear. Will the 3m SMR w/ a 10 inch 2000 rpm buffer and foam pad take care of this? If so, do I need to remove the Zaino before doing this with alcohol/water? Thanks!
Guest
Posts: n/a
I've used 3M's 'Swirl Mark Remover', as well as their 'Swirl Mark Remover for Dark Colored Cars', after I've had Zaino on the car.
I don't believe you need to remove the Zaio prior to using the 3M product. If you choose to remove the Zaino though, you should use 'Dawn' liquid soap.
I've used the 3M by hand on some minor imperfections, and it has always worked well for me. I also make sure to apply Zaino to the area which was polished as a final step as the 3M contains "no wax".
Here is a link, sorry for using another site---needed to attach, of the problem area:
http://www.ls1tech.com/forums/showth...82#post1551882
ChrisFrez
03-29-2015 09:43 PM
squirrels
09-24-2001 02:31 PM
Lt1Diablo
09-14-2001 12:47 AM
