Best way to wash the glass?
I've tried method I can think of, and I -still- see streaks on my car's windows! Not always, just at certain angles and in certain light, but it still bugs the hell out of me. Is there a way to completely get rid of streaking on glass?
2001 Onyx Black Z28 M6
Pro 5.0 shifter, BMR STB, BMR SFCs, BMR panhard rod, !CAGS, T/A leather seats
Have you tried cleaning the glass with a cotton bath towel instead of paper towels, I get a more even finish that way.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
96 Black Impala SS
www.zainobros.com
Remember #3
I noticed you ride is a 2001. I bet your streaking becomes worse not only when/if you cleaned your windows in the heat sun, BUT if you cleaned them in an ideal place that cool and shaded, then parked her in the sun then you would start to see streaks and stuff that werent there previously?
Anyway if you noticed when you leave a new car in the sun/heat the windows seem to haze over more quickly than a ride that is two or three years old. That is because the plastics and chemichals in the interior (especially the dash) give off "gases" that rise to the windshield. The process slows down greatly after 2 years. I noticed this was even worse in Camaros (big dash/big window). Just some info
I was watching Dream Car Garage one night and in their detailing segment they used window cleaner and very fine steel wool. Anyone try this? It seemed to work for them.
96 red Z
m6, t-tops,
subframe connectors, LCA's, tubular panhard rod, skipshift eliminator, K&N FIPK, BMR stb, 17"SS rims, 3" Magnaflow Cat-Back exhaust and other misc debris
96 red Z
m6, t-tops,
Yes newspaper works wonders and if you do miss a spot just go back over it with the
paper you finished wipeing with.
94 Z28 M6 Black
Mods;K&N CAI,Pace setter cat back, gutted cat,TB coolent bypass,Skip shift unplugged,JET 160* fan switch and Hypertech 160* power stat,LT4 Hot cam kit, Hurst shifter.
94 Z28 M6 Black
I've tried them all, including newspaper, and get the best results using Sprayway Glass Cleaner and a cotton towel. Sprayway, unlike most glass cleaners, contains no ammonia. The ammonia is what normally causes streaks, especially in warm/hot weather. If it's any indication, the majority of glass shops here use Sprayway. You can buy it at most janitorial supply places.
2000 SS
2000 SS
I use newspapers. You'll know you're doing it streak free when you start to hear the print make sqeeking sounds as you rub it over the glass. Also try not to use a ton of spray. Over spraying will also contribute to streaks
EDIT:
Just noticed the date WTF? I was 15 years old at the time!
EDIT:
RX Speed Works
07-24-2015 02:25 PM
07-17-2015 02:47 PM
07-10-2015 02:23 PM
