Engine Cleaning
#17
CD2 also makes an engine cleaner for the outside.. That is what I was referring to. You spray on the degreaser/cleaner, wait 10 minutes, hose it off, let the engine run for a few minutes and then spray on the detailer. This stuff is awesome!
Many things have changed since this picture, but you definitely get the idea. BTW, it is always this clean!
http://www.jackz28.com/myz/MyZ/dsc00499.jpg
#18
Originally posted by moparman
The opti is the distributor on the LT1 engine used from '93 -'97 on F-bodies. It mounts below the water pump on the front of the engine. Susceptible to failure under moist conditions.
#19
AFIK, the V6 is not susceptible to water damaging the ignition.
Yes, CD2, as well as Gunk, makes a fairly good engine cleaner. I wasn't even thinking about the CD2 engine cleaner. If I'm under the car, I usually spray the block with brake cleaner if needed. The brake cleaner seems to do a better job than the engine cleaners.
F'n1996Z28SS
08-23-2023 11:19 PM
