How long should I let Klass Glaze dry?
Would 3-4 hours in 65-75 degree weather (in shade) be fine? The directions say overnight is best....but is that necessary? I just tried wiping it off and it seems fine.
I usually let the Klasse SG cure for at least 1 hour, usually 2, and everything turns out fine. 3 to 4 hours is more than sufficient for Klasse in warm weather. Klasse, like most polymeric products, benefits from as long a cure time as possible, which is why they recommend overnight. The theory is that the longer you let it cure, the better it will bond to the surface. In reality, I think it completely bonds in a couple of hours. Don't be afraid to experiment with it though, you never know when a slight change in application may reap better results...
I should add that this is just the way I use Klasse and it seems to work. Maybe some of the more experienced Klasse users can give you better pointers. I have heard several different methods of using Klasse so you may want to dig further into the product tricks and tips to learn more about what generally works best for the K users. Foxbat, you out there??
*Mike's 1992 Camaro RS 25th Anniv.*
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
Show Car Shine by ZAINO! - Special Thanks to Sal Z!
[This message has been edited by MikeLS (edited May 27, 2002).]
yeah mike,
i'm lurking in the shadows as usual..
as for cure time, 1 hour works fine for me, but i guess if you (davey) can wait longer you may get even better results.
let us know!
-fox
BLK 94 TRANS AM M6
B&B TRIFLOW CAT-BACK
SLP-CAI
GRANATELLI M.A.F.S.
T/B COOLANT BYPASS
SLP T/B AIRFOIL
SLP SKIP-SHIFT-ELIM.
BMR S.T.B.
CHARCOAL LEATHER,T-TOPS,
EVERY FACTORY OPTION
CHROME SLP WS-6 17 X 9 WHEELS & 275/40/17 GOODYEAR EAGLE F1's
let us know!
-fox
BLK 94 TRANS AM M6
SLP-CAI
GRANATELLI M.A.F.S.
T/B COOLANT BYPASS
SLP T/B AIRFOIL
BMR S.T.B.
davey,
i also forgot to mention that properautocare.com also carries a high-gloss acrylic spritz called "SONUS" made exclusively to go along with KLASSE that absolutely ROCKS!!
this stuff is acrylic and made of the same ingredients as KLASSE. give your car a spraydown with it after washing/waxing with KLASSE and the results will positively astound you. it adds even more slipperiness and wetttnesss to the already fantabulous gloss of KLASSE glaze.
later,
-fox
BLK 94 TRANS AM M6
SLP-CAI
GRANATELLI M.A.F.S.
T/B COOLANT BYPASS
SLP T/B AIRFOIL
BMR S.T.B.
later,
-fox
BLK 94 TRANS AM M6
SLP-CAI
GRANATELLI M.A.F.S.
T/B COOLANT BYPASS
SLP T/B AIRFOIL
BMR S.T.B.
05-01-2015 01:14 PM
