Need Info On Wet Sanding!!!
I had a small place on my front air dam that I touched up, and the paint is higher than the paint around it now, could I wet sand it down? And how do you wet sand?
I would use 2000 to 2500 grit wet/dry paper, keep the paper and the paint area very wet and using slight pressure, keep the paper moving in a back and forth motion, for a little chip like that, no more than a couple of minutes sanding should level it down, you will need some rubbing or polishing compound at that point, you certainly do not want to sand off all the clear coat in that area.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
96 Black Impala SS
www.zainobros.com
Remember #3
CARiD
09-07-2015 08:21 AM
