paint on fender from dumbass opening door on it
A good rule to follow is to use the path of lease resistance, in other words use the most harmless methods first.
Try a very mild rubbing compound or clay bar first, if that doesn't work try a more aggressive rubbing compound.
Good luck.
Jeff
1996 Black Z28 M6; Stock.
1994 S10 4X4.
Good luck.
Jeff
1994 S10 4X4.
Try the clay bar first, I've remove "scuff" marks added, before with it. If that doesn't work try the mild polishing compound, 3M is a good one, like Jeff suggested.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth, Direct-Flo lid with Holley filter and Mallory polished MAF ends.
Louisville, KY
Louisville, KY
I've had the same problem before as well. I found that a small dab of Meguiar's Body Scrub will take it off pretty easily. Just rewax/polish the area after your're finished for protection.
*Mike's 1992 Camaro RS 25th Anniv.*
Dark Red Metallic / Flame Red
Flowmaster Crossflow, K&N
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
20% 3M Panther Black Tint
zaino, Zaino, ZAINO!
My Guitars!
My Guitars!
Patricklt1
04-24-2015 06:29 AM
