streaks with Z-6
streaks with Z-6
I'm a 3 year zaino user and use it in detailing customer's cars. But I always have a problem with streaking with the Z-6 spray. I have to do it over and over to eliminate streaks. I've tried it with it in the shade and in cool temps, also in the sun when its hot. No matter what conditions, it streaks. I use the fieldcrest towells too. Whats the problem?
Guest
Posts: n/a
I just read this on Zaino's site.
Using Z6, you're supposed to use an amount, about the size of a dime, per square foot. It is also suggested that you could try and use a 50/50 mix of Z6/water. Check out their site for alot of helpful tips.
I just think you may be using too much.
Just sprinkle the surface with Z-6, no dousing, wipe the product around evenly with a clean towel, flip the towel to the dry side and it will evaporate evenly and one more pass with the towel and it should be perfect....
Originally posted by Kevin V 2002 SS
It is also easier to spray the towel instead of the surface, especially if the surface is hot.
99blackz99
07-07-2003 07:52 AM
JSK333
09-22-2001 07:50 PM
