What is your favroite car washing soap?
What is the deal witht he wash and wax soaps? are all the soaps the same?
86Z28,Gm 350,Jet fan 180 switch,Jet perf chip,Q-jet, ,Edelbrock performer intake,Edelbrock headers & cat-back,MSD 6AL,Taylor spiro-pro wires,World class t-5,Hurst short throw shifter,Aluminum driveshaft,BW posi disc rear 3.45's & a posi,PBR calipers and 12 inch rear disc,Crossed drilled front rotors,Earls' braided brake lines, Carbon metallic pads (front),VGX pads(rear),SSM subframe connectors,Edelbrock strut tower brace,GM wonderbar,KYB struts & shock,Jamex lowering springs,Polygrapite bushings all the way around,poly trans mount & torque arm mount,Hotchkis LCA's & panhard rod,Rancho limiter strapes,Jet black,tinted windows, 92 z wing,New 92 z28 16 inch rims,Dual snorkel aircleaner,K&N,1,200 watt system. All fluids are syntheic (mobil 1&Gm)
Zaino Z-7 Show Car Wash, but usually you should use the same name brand car wash as the name of your auto polish or wax.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
96 Black Impala SS
www.zainobros.com
Remember #3
Please...Pass the Zaino....
***Authorized Zaino Bros' Show car Polish distributor***
george13@adelphia.net
Mr.Clean all purpose cleaner! Does not strip wax and leaves no water spots. Also works well on tar spots and bug splats.
Many people think that it harms the paint. It does not, just don't use the floor cleaner!
If you want to strip the wax use Palmolive dish liquid.
ZAINO!!!! It actually has a small amount of polish in it to help keep the great shine.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth
Louisville, KY
Louisville, KY
I've been happy with Mothers products.
96 red Z
m6, t-tops,
subframe connectors, LCA's, tubular panhard rod, skipshift eliminator, K&N FIPK, BMR stb, 17"SS rims, 3" Magnaflow Cat-Back exhaust and other misc debris
96 red Z
m6, t-tops,
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
