Zaino: Experiemented - ZFX vs. NO ZFX.. NO DIFF??
Old 11-23-2002 | 10:23 PM
camarosource's Avatar
I decided to see if the ZFX indeed speeds up the drying process.
I Wiped one side of my hood with Z2 (NO ZFX), and then took out 2 mins and mixed in the 2oz. bottle Z2 and ZFX. Applied it to the other side of the hood.
Waited approx 45mins, returned.. Assuming the NO ZFX would be wet (as it's said it takes overnight to dry), I was shocked to discover BOTH were dry exactly the same.
Does this indeed mean ZFX does not do anything? I mean, heck.. $30 for 2ml is not exactly cheap :-)
I mix 1/2 oz. Z2 with 1-2 drops ZFX.
If I do 1 oz and 2-3 drops ZFX I waste 1/2 oz as I have 1/2 oz remaining after the 3 coats.
Old 11-23-2002 | 11:05 PM
TA25th's Avatar
I think that's where you missed the point of the ZFX. It is designed so you can take it off almost as soon as you are done with your car, instead of PERHAPS waiting overnight to take it off. If the humidity is fairly low and the temperature is high enough, the ZAINO will dry pretty quickly without the ZFX, and then there is no need to wait overnight to take it off.
HOWEVER, I believe you MUST wait 24 hours to recoat the car with Z2 or Z5 if you do not use the ZFX. The 24 hours is a curing time needed for the polish to properly adhere to the previous coat. By using ZFX, the
CURING time is greatly diminished, and you can immediately topcoat the car with up to 2 additional coats for a total of 3 coats in a 24 hour period.
So to sum it up, the main feature of the ZFX is so you can put up to 3 coats on in a 24 hour timespan. The faster drying when using ZFX is nice, but is not really what it is made for. If you do not use ZFX, it may or may not dry as fast, but you still have to wait 24 hours before topcoating it.
Chip in here if I'm wrong Kevin, but I believe I am correct.
Old 11-24-2002 | 04:57 AM
JackZ.Twenty8's Avatar
That is correct! ZFX is unique, in that it only requires only about 5-10 minutes(usually not more than 20) to dry, if applied in thin layers, as instructed. The drying time will also be affected by the temperature, obviously, so the hotter, and less humid it is, the quicker it will dry. No more than 3 coats in a 24 hour period.
My Zaino testimony!
http://www.jackz28.com/myz/dsc00328.jpg
Old 11-24-2002 | 07:03 AM
hcvone's Avatar
As said with ZFX I can start removing the polish as soon as I finish applying it to the last panel of the car, the ZFX also forms a tighter bond which means longer lasting protection
Old 11-24-2002 | 11:40 AM
Kevin V 2002 SS's Avatar
Same here, when I finish applying it is already dry on the areas I started on. Without the ZFX it doesn't. Waiting 45 minutes isn't a very good test since, both SHOULD be dry.
Your analogy is like comparing 2 long distance runners. One may run the mile in 5 minutes and the other is very slow and does it in 15 minutes, but you wait 20 minutes to see if they are finished and they are. Then saying because they were both done by 20 minutes they are they run the same times.
Old 12-02-2002 | 06:39 PM
Klypto's Avatar
great analogy kevin, btw im about to email you with the order i talked to you about (email, im Binkyboy88)
ill be getting ZFX
thx
cory
Old 12-02-2002 | 09:43 PM
Mr.Whitey's Avatar
Kevin, I'm glad that I am not the only one to have ever made this mistake. You might as well sell it!
Old 12-03-2002 | 08:34 PM
You have to remember which Kevin is which. Kevin SS is the TN Zaino distributor and me, Kevin V 2002 SS, I'm not a Zaino distributor. I do keep ALOT of extra supplies on hand for all the locals around the Louisville, KY area though.
And Carl don't confuse them with your "theory"!!!!
revrider
Cars Wanted
04-05-2016 10:06 AM
09-18-2015 03:46 PM
95z_28_camaro_4_Ivan
08-25-2015 03:59 PM
force10
07-30-2015 04:56 PM
realistyc
07-28-2015 07:32 PM
Quick Reply: Zaino: Experiemented - ZFX vs. NO ZFX.. NO DIFF??
