Any 5th gen free mods?
Old 03-04-2011 | 04:59 PM
km9v's Avatar
I haven't found any.
Old 03-05-2011 | 11:18 PM
97QuasarBlue3.8's Avatar
Re: Any 5th gen free mods?
Except for the #5 and #20 fuse-pull for the SS, to reset the fuel map if you haven't done so already.
If you didn't know about this one...cheap/regular gas used when the dealer fills up the car before delivery causes the car to adjust the fuel map. The programming in the ECM is only uni-directional. Once the fuel map has been adjusted for cheap gas, it can't reset if the octane goes back up. I burned through the first tank of 'dealer gas', filled up with premium, and then reset the ECM about 50 miles later. Nice difference!
Old 03-06-2011 | 08:30 AM
JasonD's Avatar
Admin Emeritus
Not any that I know of. Seems that did all of the hard work for us. Or fun work.
That, my friends, is good engineering.
Old 07-01-2011 | 11:40 PM
TechAFX larry's Avatar
If you disconnect the Wiring Harness from the Injectors on each side, you can carefully tuck the Harness behind each Injector. Then reconnect each clip & the wiring's well hidden.
After you're done, 1 more ugly thing disappears out from plain view on the top of your engine.
Old 07-04-2011 | 08:52 AM
Mucker15's Avatar
one free mod ! remove the water bottle which resembles a dead goose , it gets more air flowing and the goose weights 9 lbs according to Hot Rod mag, well thats free if you can live with out washer fluid if not you can spend afew $$ and replace it check out the thread here on Cz28 for more (and add the air scoop also not free )
https://www.camaroz28.com/forums/sho...d.php?t=816973
black out your tail light bezels is a pretty cheap mod
Old 07-04-2011 | 11:46 AM
km9v's Avatar
I don't have a CAI.
Old 07-04-2011 | 12:52 PM
Mucker15's Avatar
oh well
a KN filter is a cheap mod you can replace your stock filter
Old 07-04-2011 | 06:23 PM
km9v's Avatar
A K&N filter is the only the only mod I have at this point. I'm saving for exhaust.
Old 07-04-2011 | 06:45 PM
Mucker15's Avatar
there so many options
Old 07-05-2011 | 07:52 AM
2010_5thgen's Avatar
mucker, where did you get that air scoop at? does it help feed air to the intake better? i disconnected my washer fluid hoses anyways because of my hood, so i may take the whole washer fluid bottle out.
Old 07-05-2011 | 09:13 PM
Mucker15's Avatar
got it from adm all the info is here
with out the bottle I felt a difference and with the scoop it was def better, its nto going to change the world but more air is good more air better directed is better I was happy with the mod
Old 07-06-2011 | 07:36 AM
you felt the car got better air flow by just getting rid of the washer bottle? hmmmm. maybe ill pull mine out tonight.
is this it right here? http://www.admperformance.com/produc...66&product=239
Old 07-06-2011 | 11:20 AM
Mucker15's Avatar
yes thats it Andy is a pretty cool guy too,
yes it def was better without the bottle and even better with the scoop
Old 07-11-2011 | 12:37 PM
Kendell347's Avatar
I'll agree the ADM air scoop is a great mod
Old 07-11-2011 | 01:09 PM
i think im going to go for it.too bad we dont have our metal bender any more. id be able to make my own.......
Quick Reply: Any 5th gen free mods?
