95 Zee Cat delete?
95 Zee Cat delete?
Hello again all, got a couple ????'s about deleting the cat on my kids 95 Z28. If you guys don't mind throwing me a bit of info/thoughts on it that would be awesome.
1. Will deleting the catalytic converter affect backpressure, pcm or the likes? Just don't want a engine light staying on because of this. Just curious because there is no o2 sensor after the cat so would it make the car run worse? I'm sure there won't be a significant benefit or anything just want to ask before just cutting the thing out. The flange holding it is kinda rusted though so trying to be pre-emptive before it falls off anyway.
2. Kids asking me if the car will sound better or worse without it, I have no idea so I figured I'd ask.
3. Fuel mileage, any worse or no.
If you got any thoughts or whatever it would be great.
Thanks in advance
Thanks in advance
Re: 95 Zee Cat delete?
No codes in OBD-1 from removing the cat. Anyone with a sensitive nose and basic mechanical knowledge driving behind you will be able to tell the cat has been deleted.
No need for a tune, any increased air flow into the engine will be picked up by the MAF sensor.
Might sound very slightly louder, probably not much.
Not much in the way of power improvement, unless it was seriously plugged up. Way back in the day, Lingenfelter was building 383ci, 400 HP, street legal LT1’s. He said even at that HP level the cat resulted in less than 5 HP loss.
Will not materially affect gas mileage.
Thanks for the positive feedback. I just had a long time member tell me I'm a poor administrator.
Don't you just love it when they cloak their hatred in a false shroud of Godliness.
Sir;
(Grow Up?), please keep your lack of wit to yourself sir, it embarrasses you. If this is a reflection of your admirative abilities, I can understand why no one posts to this board anymore. Please do not bother to answer this post, for I will not read it.
Have a great day, and GOD bless.
Lol, man. I don't think you could have put it any better on the godliness quote! Thats rings so true in so many ways. I've read so many threads on here where you try to help someone and they just don't take you're advice, it boggles my mind.
Cheers
Cheers
Thanks in advance
Thanks in advance
Hey! bout deleting the cat on your 95 Z28, it does affect backpressure but it’s not too dramatic. Usually, there won’t be PCM issues, but it’s smart to invest in an O2 simulator to avoid that pesky check engine light. As for sound the car will definitely sound better getting a more aggressive tone.Just keep in mind it might affect fuel mileage – it shouldn’t get worse, but it really depends on your driving style. In short do it wisely and prepare for a better sound but remember, you might lose some efficiency if the car is driven hard. Let us know how it goes!
I notice your IP address is from Poland. Maybe that would explain a misunderstanding of US OBD requirements. But wait, in your profile you entered "UY" for Uruguay. Might want to clear that up, or your account will be deleted.
ADMINISTRATOR
ncmoneygetter
10-05-2006 06:59 AM
Tattooedlife
10-08-2004 12:03 PM
