1995 Z28 - 1 Owner - Significant Updates - Clean - Garage Kept Since 1996
Old 09-07-2024, 09:32 PM
WhiteTigert56's Avatar
Original Owner
Garage Kept since Mid -1996
Less than 73,000 Miles total on the Vehicle
(Documentation Validating Low Mileage will be provided)
VIN: 2G1FP22P4S2213183
Modified 383 Motor (6.0 Liter) with paperwork.
Less than 2,000 Miles on the current motor.
Price $10,500
If Interested, reach out to me at WhiteTigert56@gmail.com
Listing many but not all upgrades here.
Incl. Spec. Grind Cam, Eagle Steel Crank and Alum. Forged Rods, Alum. Forged Pistons (11.1), AFR 190cc Heads, Manley Valves 2.055 x 1.60.
Significant Suspension Mods, Billet Alum LT1 Trail Arms, Eibach 1.5" Lowering Kit / Poly Bushings / BMR Bolt-In Torque Arm & Driveshaft Safety Loop
Comp Cams Pro-Mag Rocker Arms 7/16" Stud - 1.6 Ratio with ARP Rocker ARM Studs, Guide Plate. MSD Ignition System, Elec Water Pump,
1 3/4" Ceramic LT Headers, 200 Amp Chrome Alt., Moroso Cold Air Induction,
17" Wun-Gun Rims, 275/40/17 Nitto Tires (new), Spec Stage 3 Kevlar Clutch, 36 lb Fuel Inj.,
255 gph Fuel Pump+, New Radiator,
RaceSearch.com SB Chevy Pro-Drag Oil Pan,
LT1 Edit and Data Master Programming Software with Data Files.
377.45 RWHP
384.16 RWTQ
(Dyno sheets available)
Slotted and Cross Drilled Rotors with Ceramic Brake Pads and Dot 5 Brake Fluid.
Upgraded Brake and Protected Lines.
Custom Flame Engraved Chrome Valve Covers.
Custom Paint Work (Black is Paint not Wrap)
Rare Flame Red Cloth Interior - Excellent Condition.
Aftermarket Alpine Stereo System, CD/MP# with Faceplate/Holding Case, Subwoofer.
New A/C Compressor
Trunk Mounted Battery (Plug in Charging System for Battery)
Significant Documents for Oil Changes, Radiator Flushes,
Brake Work, Sensors, T-56 Transmission Work, etc. Available. Comes with Car.
Located in the Fort Lauderdale area.
Please inquire with questions. More pictures available upon request.
Thanks!
WhiteTigert56 is offline
Chris Iglehart
10-13-2021 02:04 AM
Jditlfm
09-23-2008 09:23 AM
Why Try
10-23-2006 08:04 PM
4mulaJoe
10-17-2005 03:02 PM
4mulaJoe
West South Central
10-15-2005 12:18 PM
Quick Reply: 1995 Z28 - 1 Owner - Significant Updates - Clean - Garage Kept Since 1996
