Lost the chip in my 1997 Z28..... but it works fine
Old 09-08-2024, 01:33 AM
BattleCockBTK's Avatar
Hey Guys,
  1. . I recently picked up a used BCM from a local Junkyard. My old one had issues and whatnot. I knew I had a 1 in 15 chance of having one with the right resistance... I was beyond happy to find out that my decision paid off. Here's the vexing quandary I have: I lost the chip in my key, I tried and never had luck finding it, but somehow my car still starts and drives perfectly fine. I am more than 100% positive that I'm the only person to take it apart and mess with any components I see no signs of a bypass either. How is this possible? The security light has been solid for about 3 years now and I've had no luck trying to program a new or used key fob because of it. I'm happy it doesn't leave me stranded, but I lose sleep over such things. Any and all responses are appreciated. Thanks in advance
BattleCockBTK is offline
Old 09-08-2024, 09:08 AM
Re: Lost the chip in my 1997 Z28..... but it works fine
You checked the wires on the steering column?
http://shbox.com/1/vats_bypass.jpg
Injuneer is offline
Old 09-09-2024, 04:17 PM
Then there's also the ability to bypass the theft deterrent relay simply by unplugging it and connecting the yellow and purple wires together, and adding a 50Hz signal generator to provide the fuel enable signal to the PCM.
http://shbox.com/1/starter_charging_96.jpg
4th Gen LT1 F-Body Tech-PassKey/VATS
Injuneer is offline
1993Z28LT16SPD
03-18-2012 07:15 AM
tyrone_biggums
19
09-29-2009 06:29 PM
Counted Out
08-26-2008 12:04 PM
ChevyTuffD.A.
07-16-2005 01:28 PM
Ryan's LT1
06-02-2004 06:21 AM
Quick Reply: Lost the chip in my 1997 Z28..... but it works fine
