South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Lt1 edit with 2 Vin's and 2 PCM'S
Old 08-26-2004 | 11:37 AM
philcam01's Avatar
Lt1 edit with 2 Vin's and 2 PCM'S with laptop !!!!
I have a complete setup inclueding 2 vin's with the 2 Pcm's. 1 pcm is erased and needs to have a stock file put back in it from a local dealer the it will work again. The other one is in working order when I removed it from the car. This will come with everything inclueding the cable and plug for a OBD II and will work on a 95 or a 94 if you convert the plug to OBD II. E-mail me for more info if needed. I'm open for offers
Old 08-26-2004 | 04:40 PM
blackz151's Avatar
Re: Lt1 edit with 2 Vin's and 2 PCM'S
what are you lookin to get?
Old 08-26-2004 | 04:51 PM
philcam01's Avatar
I looking to get $350 OBO for everything inclueding the laptop that runs it all !!!
I for got to but that in my first post
this will come with a compaq laptop to run the hole thing. The laptop is old but it does the job with no problems .
Old 08-26-2004 | 06:29 PM
97s10ondubs's Avatar
so you gotta use one of the pcms right cause its programmed into the edit? and 350 shipped?
Old 08-26-2004 | 08:55 PM
philcam01's Avatar
you can use ethier one of them, but one will have to be reloaded from a GM dealer before you can use the edit on it again. $350 is shipped
Old 08-27-2004 | 02:28 PM
both have to be reloaded before use? and how much does it usually cost to reload?
Old 08-27-2004 | 04:54 PM
philcam01's Avatar
just one of them has to be reloaded from the dealer and the other one is good to go. I can get it done for $50 around here.
Old 08-27-2004 | 05:18 PM
more ?, does it have the software cd? is it the one pcm locked(with another purchased) or unlimited tune? if i think of more ill ask, also you said obo, what can you do with that?
Old 08-28-2004 | 12:18 AM
philcam01's Avatar
it's locked to both of the Pcm Vin that I have. So yes it's locked with one Pcm and I bought the second one added on. shoot me a e-mail with a offer and will work something out.
DirtyDaveW
12-01-2016 05:37 PM
Bearmans
12-03-2014 05:28 AM
DropTop91
22
08-08-2002 10:53 AM
Caps94ZODG
08-05-2002 06:31 PM
Bando
08-02-2002 02:18 PM
Quick Reply: Lt1 edit with 2 Vin's and 2 PCM'S
