South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
LT1 shifter problem
Old 11-03-2002 | 06:23 PM
Kumar 98Z's Avatar
Unhappy LT1 shifter problem
This is for my g/f 's 97 Z. When coming down from P to R or D the shifter works normally. When coming back up however from 2 to D, D to N, N to R, R to P the shifter feels very sloppy and loose/ as if the little wheel on the shifter is not seating in the notches properly. Sometimes you have to slam it forward to get it to lock into park. Do I need to replace the shifter? Im thinking the plastic notches the shifter seats in for each gear are worn. The car only has 50k. Any suggestions?
Old 11-03-2002 | 08:24 PM
Camride's Avatar
Pull the console off and look at the teeth, it takes 2 seconds to pull it off, just be careful about the bulb under there because the wire isn't very long. I wouldn't think that it would wear out, I've never heard of that happening before. But if it is it shouldn't be hard to find a replacement at a junkyard, just go to J&B's on 50. Hope this helps broh
Old 11-03-2002 | 09:25 PM
2002Z28SSConv's Avatar
Sounds like something might be loose somewhere. Be sure to crawl underneath and make sure the bracket is tight where the cable meets the transmission.
Old 11-03-2002 | 10:20 PM
Mr. T's Z's Avatar
Ditto that check where the cable meets the trans. I had this happen on my 91 and the bolt fell out of the linkage. Just had to get a new bolt no biggie. Hope this helps.
Tyler
Old 11-04-2002 | 07:36 AM
Kumar 98Z's Avatar
everything under the console seems tight. i will look at the cable under the car, thanks for the tip
Old 11-04-2002 | 08:39 AM
'94 Bad A Z28's Avatar
Kumar, lol, luv the sig.
Old 11-04-2002 | 08:42 AM
Kumar 98Z's Avatar
thanks
Old 11-06-2002 | 07:10 PM
Kumar 98Z's Avatar
Talking FIXED!!
ok found out what the f#$! the problem was, one of the bolts that holds the shift cable bracket to the trans pan was missing and the other was loose as a mo fo.
Old 11-06-2002 | 09:23 PM
Good job dude! Thanks for the update. Glad to be of help.
Old 11-06-2002 | 10:29 PM
Soma07's Avatar
Thats good ol GM quality for ya
Jazsun
12-29-2014 12:14 PM
tds1213
11-27-2014 12:55 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: LT1 shifter problem
