LT1 True Duals and Rearend
I am selling the true dual setup of my 93' Z28. The setup is 2.5" X-pipe with Spintech street mufflers. It's ran under the rear axle with Corsa clone tips on the end. The only thing this exhaust needs is new hangers welded up wherever you want to put them. I had this exhaust bolted to Pacesetter long tubes, but it should also bolt up to Jet Hots and Hookers. I'm in the Orlando area and want to sell these locally. Heres a quick rundown of what this exhaust cost me and some pics of it on and off the car.
Spintech mufflers: $140
Corsa clone tips: $100
Jegs x-pipe kit: $100
Labor for installation: $300
I'm asking $275obo for the exhaust. I can knock some money off if you don't want the back half of it so you can dump it before the axle. I also have a posi 3:23 rearend for sale that has the brakes and all suspension still on it. Make an offer on the rear.
Do you have any pictures of it up on a lift? I've had issues getting pre-made exhaust to fit on my car (the pinion angle and size of the Ford 9" gets in the way) and wouldn't mind something that goes out back and a little quieter than my current true duals.
guionM
9
08-29-2002 01:48 PM
