1LE Springs
Re: 1LE Springs
Originally Posted by redzracing
does someone have the part number off hand for these?? I looked on shoebox's site and didnt see them
The front springs I have had my hands on have the following rough dimensions.
P/N Wire Diameter Number of Coils Outside Dia. Free Length
(Stock) 22077195 .570" 9 4.59" 15.5"
(NOS) 22197228 .565" 9 4.56" 15.5"
(NOS) 22077196 .570" 10 4.58" 15.5"
(1LE) 22132561 .580" 9 4.52" 13.75"
To identify the rear 1LE springs look for a plastic spacer on a tightly wound spring coil near the top. This coil must be the progressive part of the 130-170 lb/in. It has the partnumber 22132889 it is also a good discontinued 1LE number. [http://www.gyrhead.com/special.htm]http://www.gyrhead.com/special.htm[/URL] , Has the rear spring.
To identify the 1LE front spring. Look for a spring that is shorter than stock by 1.75" and has .580 wire. I have not had my hands on the 22132887 1LE spring so I can't give you a way to identify it, but it should be similar to the 22132561.
My ride height is 28" at the front fender lip and 27 3/4" at the rear fender lip.
