is a 24mm rear sway bar worth getting?
Re: is a 24mm rear sway bar worth getting?
thats the stock ws6 supension option rear size for thirdgens, it would keep the rear end more firm i would guess.
i run no front sway, stock use to be 36mm hollow i think; and i would at least use a stock rear 24mm sway bar for a drag/street car, even helps with handling also.
Autocrossers don't often go above 21mm, and many prefer the 19mm. Comparing the 3rd gen size with a 4th gen setup isn't quite fair. The bigger bar in the rear will break loose easier.
Originally Posted by zo6vette
would a 24mm rear sway bar worth getting? would it help with traction? what do you guys think?
