2inch drop and NOW too much wheel hop, what do i need?
Old 08-28-2004, 11:31 AM
  #16
Xride's Avatar
Re: 2inch drop and NOW too much wheel hop, what do i need?
sswin24, yes very missleading, in your original post you say "my 2 drop with koni adj. shocks"
As for UMI, good luck.
Originally Posted by dmoor88
you're going to be rubbing hardcore with 315+ in the back with a 2" drop but good luck.
hes going to rub with them, but should be able to stuff them under if he gets the proper back sapcing.
335s will NOT fit without modification.
Xride is offline
Old 08-28-2004, 11:48 AM
  #17
NOSCaMaRo's Avatar
With a 2" drop you are def going to want/need the adj. PHB. It will allow you center the rear end which most likely has shifted to one side when you lowered it. the 315's are going to rub, the adj. bar will allow you play with it and help to elinimate some of it.
The relocation brackets are great to get your traction back, with them installed it will allow you to place the control arm back in the correct geometry it was before it was lowered, without them you will have bad wheel hop. When you install the brackets use the lowest setting. UMI makes some killer quality parts, you'll like them.
Good luck
NOSCaMaRo is offline
carguy0119
04-11-2016 11:11 PM
mschmidt33
03-15-2015 07:20 PM
SAR2K
09-01-2002 10:49 AM
wytblur
08-05-2002 02:03 PM
Quick Reply: 2inch drop and NOW too much wheel hop, what do i need?
