32mm 1LE Sway Bar Bushings/End Links
I am thinking about buying a 32mm 1LE sway bar and was wondering where do I buy new bushings and end links? I read that GM sells some, but are they poly or rubber? Thanks.
-Dustin-
-Dustin-
Re: 32mm 1LE Sway Bar Bushings/End Links
1LE Stabilizer Bar Endlinks (GM p/n 10221779) $7.05 (Need two)
1LE Front 32 mm Stabilizer Bar Insulator (GM p/n 10288551) $7.66 (Need two)
The bar insulators are rubber, the end links are black with white plastic isolators.
Might be poly, but they work and they fit. In general rubber is better than poly and GM actualy tests their parts.
Z28
Z28
I read this in Camarocracy's thread about GM's stuff, and SLP is selling bushings for $3.50 online. I am going to get the SLP/GM ones if nothing turns up at Summit when I stop after class today. I have $20 in Summit bucks to spend. Thanks.
-Dustin-
-Dustin-
Yea, I saw that buying the duro ones from SLP would cost around 14.XX after shipping where as I can stop at Summit, like I did yesterday and get them for $12 and they are poly. Thanks guys, for future information, Summit has both items you'd need.
-Dustin-
-Dustin-
96SilverRam
11-20-2016 11:19 AM
