32mm Front Swaybar
Yeah. I saw an auction on ebay for some 1LE bars for cheap, just figured I'd check the numbers and make sure it was an actual 32mm bar. Apparently, I already missed the auction though . The damn "time remaining" clocks on ebay aren't worth sh%t .
Re: 32mm Front Swaybar
Sway bars are a very good addition to a f-body. I put some G2 swaybars on my 95 formula and the handling is 10 times better. It used to roll bad but its much improved. Stock front is 30 mm and stock rear is 19 mm. The G2's are 32.5 and 21.5. Good luck.
You also would want to look at more than just diameter. Like whether it's hollow or not. Also, what kind of material is it. My BMR swaybar is chromoly. Which is stronger (and lighter) than the steel in the the 1LE. Just food for thought.
BLK1997Z28
05-01-2015 12:23 PM
