4th gen 1le springs and rear swaybar
Hey Im looking for some of these and was trying not only to get advice on where to look other than maybe here but double check on the spring rates and bar size
Front rate is 360lb/in linear
Rear rate is 130-180 lb/in progressive
Rear bar is 21mm hollow
.. is all that correct? I have hotchkis springs and a bent up (from accident) 21mm solid rear bar and the hotchkis springs lower the car unevenly at the moment and far too much for my daily driven car with longtubes and 3" duals with cats... its pretty damn bad. I wanted as stiff a spring as I can find that keeps the stock ride height and found these to be substantially better than stock but if there is another set any one can suggest I would like to hear about it
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
Re: 4th gen 1le springs and rear swaybar
Hmmm, I have both 1LE sway bars and I dont think the back is hollow but I may be wrong. It is sure heavy. The 1LE bars made the stock bars look weak and shizzle.
Oh and 1LE swaybar sizes are 32mm front and 21mm rear
.. is all that correct? I have hotchkis springs and a bent up (from accident) 21mm solid rear bar and the hotchkis springs lower the car unevenly at the moment and far too much for my daily driven car with longtubes and 3" duals with cats... its pretty damn bad. I wanted as stiff a spring as I can find that keeps the stock ride height and found these to be substantially better than stock but if there is another set any one can suggest I would like to hear about it![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
The rear bar was only 21mm in 93 and perhaps part of 94, and they ran stock rear and front springs.
94 and later ran heavier springs that you listed and the stock 19mm rear bar.
The 21mm may be too much with the heavy springs.
Z28
How to bilstein hd's compare to the 1le decarbons? I would just get the 1le kit but I already have a solid 32mm front swaybar and ide want a stock 19mm rear bar. I havent had any of my emails returned from him but its only been a few days... I found some bilsteins for 295 so I may just go with stock springs and those if this proves to be more of a pain to get right than its worth... basically would it be wise to get the 1le kit and sell the front sway bar or get some stock springs and some $295 bilstein hd's?
10-31-2016 11:09 AM
07-04-2005 05:00 PM
slothgrant
08-22-2002 03:01 PM
