4th gen axle codes?
4th gen axle codes?
I have a complete 4th gen disc brake rear that I aquired several years ago. I know it is posi, but I cannot find any info on the axle code 4PF stamped into the normal spot on the housing. Does anyone know what this code means?
Re: 4th gen axle codes?
I don't think its coded to the gears. Take the cover off and count the teeth on the R&P. Or turn the axles one full revolution and see how many times the pinion turns.
The photo links aren't going to work, because I've changed servers.
It is going to be tough to do either one as the rear is currently in storage. I was hoping to figure it out by the code as I have done several times on 3rdgen cars.
07-04-2005 05:00 PM
Chris 96 WS6
33
09-03-2002 09:48 PM
stars1010
07-15-2002 03:51 AM
Doug Harden
11
07-14-2002 04:31 PM
